a9 Pro after Update .problem Help
(Topic created on: 10-19-2018 07:39 AM)
Ghost12
After update Myairtel app is preinstalled in My phone .I cant unninstall it...
13 Comments
kumaranujsid
you can't remove it untill you are using airtel sim.this app will be removed only after removing airtel sim.
JayAhir0
terepas Airtel sim he esh liye nikal de to app bhi nikal jayegi
Ghost12
it's not even the real Myairtel app ..When I click that app it goes to play store and download the my airtel app.
Ghost12
I installed the my airtel app ..But now there's 2 my airtel apps 6781ed64-83d5-4b30-93bb-4ae8578fbd02.jpg
absguy
I AM ON JIO AND I DID NOT GET ANY AIRTEL APP.....
Shiv9564
Go to apps settings disable it.
Ghost12
I can't disable it too.
theinvinsible
just unninstall your app(10mb one) and clear data of another app(567kb) present in apps and reinstall using this 567kb one. You will see only onenapp
Nishitkohli
it is coming because of airtel sim
