Same name different parts
(Topic created on: 12-07-2020 10:18 AM)
Symander5213
I don't  understand why the Exynos chip with lower specs and less heat distribution  is same price as the Qualcomm  snapdragon. That is some messed up stuff and really unfair to the users. Samsung really has to etheir sell at different price or just make one single processor. Hopefully  the s21 resolves this problem.
6 Comments
Not applicable
No it will still gt exynos
JashLathiya
exynos is made in India and Qualcomm is brand of usa...
if Samsung use Qualcomm in India they have to pay fee and more tex to gourment for using chip of others and that make your phone more costly..
if Samsung use their own Chip exynos they not have to pay any extra tax to gourment... so you get it phone on good price 😉
same in u.s.a if they use exynos in usa they have to pay extra tax...
so why Samsung use Snapdragon in USA and exynos Words Wide.
advantage of exynos is .. it produces less heat to your phone and thus your phone not heats so much as Snapdragon... it's good for your phone's health..
yes you have to compromise 1-2% in performance but if you use it with efficiency, you get 💯% of your phone..
If you found this helpful please Vote this.. to helpful solution 🙏🏻
thank you ❤️
JashLathiya
anyone can not understand in deep so , i explained it in simple terms
JashLathiya
there is not problem of fitting because every pcb designed such that it compatible to all other components so, there is no issue of fitting, that exynos not fit in
JashLathiya
now CDMA was worldwide compatible, when you get sim first time, network provider send you a sms about network certification and dms and other info you have to install it ... in some device it installed automatically...
JashLathiya
yes your right at some point
