Low sound quality on my Samsung galaxy A20 .
(Topic created on: 04-12-2020 07:19 PM)
OmarAlFaruk
I see on my Samsung galaxy A20 running low quality of sound,after 1 year.
I don't know why😰😰😰
3 Comments
you will try to clean speaker mesh (holes) with soft brush. i think if some dust problem....
Samsung_Support3
Dear Samsung Member,
1). Disconnect all accessories if anything plugged into the headphone jack like, selfie stick, headphone, Bluetooth, etc.
2). Check device volume settings:
Tap on Settings>Tap on Sound & vibration>Tap on Volume>Drag the volume adjustment bar left or right to increase or decrease the device volume.
4). Check device in safe mode:
Press and hold the Power key, when Power off icon appears > hold power off icon.
Exit safe Mode:- Restart device.
Note:- If your device functions correctly in Safe Mode, it is most likely that the issue lies with a 3rd party application that can be uninstalled to resolve the problem.
For furtherassistance kindly register your concern in Samsung members app (Samsung Member > Get help > send feedback > Ask question/Error report)
kriyanka
My samsung a20 running low quality of sound
