Issues with slow charging and short battery life on Samsung Galaxy A01
(Topic created on: 05-24-2024 11:12 AM)
HenriqueDaGama
Content: Hi Samsung Members Community,I'm experiencing issues with my Samsung Galaxy A01 related to charging and battery life. Here are the details:
Issue 1: Slow Charging
• My device takes a very long time to fully charge. Even with the original charger, it takes several hours to reach 100%.
Issue 2: Short Battery Life
• After charging, the battery drains very quickly, even with moderate use. The battery doesn't last a full day without needing to recharge.
Diagnostics Performed:
• I ran the complete diagnostics through Samsung Members, and all 21 functions, including the battery, passed as "normal."
Additional Information:
• I am using the original charger and cable.
• I have checked and installed all available software updates.
• I have tried restarting the device and closing background apps, but the issues persist.
I would like to know if anyone has experienced this and if there are any solutions or tips to help resolve these issues. Thank you in advance for your help!
Thanks, Henrique Da Gama
8 Comments
Tendai777
With reference to your Samsung A01, released in January 2020, it is possible that the reported concerns regarding slow charging and limited battery life may be attributed to the device's age.
outcast1
Which is defnitely the obviouse reason
Thank you for your input. It seems that the age of my Samsung A01 is indeed a significant factor in the slow charging and short battery life issues I'm experiencing. I'm looking into potential solutions, including monitoring the battery health and possibly replacing the battery.If you have any additional tips or recommendations, please let me know. Thanks again for your help!
Thank you for the suggestion. I will enable Developer Options and turn off animations as you recommended.
Could you please provide a brief guide on how to do this? I want to make sure I follow the steps correctly.
Thank you for your feedback. I understand that the age of my Samsung A01, released in January 2020, might be contributing to the slow charging and limited battery life issues.Would you recommend any specific actions or checks I should perform to confirm if the battery degradation is indeed the cause? Additionally, do you think replacing the battery would be a viable solution, or are there other steps I should consider before doing so?Thanks again for your help!
outcast1
Its not just your battery that needs to be replaced its your charging block too hence why its charging slow.My advice is buy a new phone
Thank you for your response. I appreciate your advice regarding the possibility of both the battery and charging block needing replacement. However, before considering purchasing a new phone, I would like to explore all potential solutions and options available.I will look into replacing both the battery and charging block as you suggested. If you have any additional recommendations or tips on how to proceed with this, I would greatly appreciate it.Thank you for your help!
Akudele7
The battery drains very quickly even moderate use
