Heat and Battery Drain after update A70 to One UI 2.5. Smart Switch shows 5 Gb of updates.
(Topic created on: 12-09-2020 09:46 PM)
michmchelge
After recent (about a week ago) update my A70 to One UI 2.5 I have noticed weird non-usual heat somewhere at the top of the screen and battery drain.
But I use my smartphone as usual. For example, some regular social media apps in background when one of enumerated is used actually:
- Spotify for listen a music
- Twitter
- Telegram
- iChan (for imageboards)
- Reddit or RIF (not both at the same time)
nothing highly loaded as we can see.
I googled about the similar issue and found some threads there in which
somebodies advised that the right way to update your smartphone is only using the Smart Switch
and recommended not to use software update via Wi-Fi. They sayid the update via wi-fi may cause such issues. Looks weird ... hum.
Is that right advice you think?
Okay. I launched first time the Smart Switch on my Windows 10 PC and ... new adventures.
Firstly, I noticed that Smart Switch shows me there is a some update weight about 5 Gb. What? But I already got latest software installed.
Screenshots: https://imgur.com/a/DegTQIo whats wrong with you, samsung? What should I do with it?
Is anyone experiencing same problem with heating and battery draining after update to the One UI 2.5 interface?
10 Comments
Jobyt
A70 after 2.5 update battery draining very fast
