Guys I think I have a problem with my camera on Galaxy A34
(Topic created on: 12-11-2024 11:11 AM)
Subbu2011
Here are some photos
This is a red line took in 10x Zoom
2 Comments
cs_member8
Dear Samsung Member,
As per your concern, regarding the camera issue. We are sorry that you feel this way. Samsung always aims to provide the best experience to our customers. We would request you to kindly perform the following steps to resolve your issue.
● Kindly check the physical condition of your camera lens.
● Use a microfiber cloth or a cleaning wipe to clean the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
Subbu2011
Thank You ❤❤😊😊
