[FIX] USB Connector Problem And Fast Charging
(Topic created on: 07-19-2020 01:48 PM)
Sumit189
Many users of Samsung Galaxy M series and A series are getting this issue of USB connector Notification and the fast charging is not showing when device is plugged to charge, it just simply shows cable charging.
Steps to follow to get everything working:
1. Discharge battery to 0% and let it shutdown then let it charge till 100%.
2. Power on and use it normally.
3. Don't charge until the battery is less then 15%.
And Uninstall updates and Reboot.
5. Before charging, GOTO settings > Apps > Show System apps > Device Care. FORCE STOP.
6. Now plug the cable, you will see FAST CHARGING.
The notification will take some time to go away, but it will go for sure.
4 Comments
Not applicable
Nice find.
Anyway my phone is working correctly now.
If problem apprears, I'll try this.
sreevijay
nice finding
BroTHOR
does it work for anyone
BroTHOR
