Battery problem
(Topic created on: 2 weeks ago)
RoadWolf95
My A06 is draining battery so much.There are not many apps or games installed on it.However it drains the battery.How to overcome this?
5 Comments
neurock
Get a new battery or upgrade phone.
RoadWolf95
This phone is only a week and two days old
john_22
sometimes could be a factory defect but do check in settings which apps are using the battery most then remove them ..
RoadWolf95
Thank you
Nova3770
What does draining so much mean? Does it at least last a day? Or less?
If you go to settings > batter you can see what is draining the battery.
