Battery problem
(Topic created on: 12-20-2021 10:50 AM)
devx594
Samsung A30s me battery problem kis kis ko h.
20 percent k bad direct switch off ho rha h. Is problem ko m 2 sal se jhel rha hu..
Kisi or ko bhi same problem h ya sirf mujhe h.
6 Comments
Not applicable
Go and visit service center
rsssssss
pehle thi mere phone m
ab nhi h
Arman-IND
overcharging ki wajah se ye issue ata hai phone ko overcharge mat karo
UP81
Overcharge kya bhai 90 se upper charge ni krta
cs-member13
Expert Level 4
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
UP81
Mujhe v h
