Battery drain problem in Galaxy A5 2017
(Topic created on: 11-03-2021 09:23 AM)
okiebhai
Can someone  help me in finding the solution the battery  drain problem in my Samsung Galaxy A5 2017???
How to fix the problem??
4 Comments
MRSingh155
Check background battery usage in device care
Put less used app to sleep
Put some rarely used app to deep sleep
Put your device to dark mode
Whenever not use close location
Hope this help you
Thankyou
okiebhai
Okay Thanks
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
okiebhai
Thanks
I will follow the same and will give my feedback
