ankushat
02-13-2024 02:17 PM in
Please solution
2 Comments
AJAB_MORIA
02-13-2024 02:21 PM in
Suggestion: Back up all your data and do factory reset (if possible).
Glimpse
Expert Level 3
02-13-2024 02:50 PM in
Which is your model , clear cache is also an option in recovery mode by connecting to laptop using usb charger cable click on volume up & power button ✅ then release once you see samsung logo and clear cache , if this doesn't helps do check factory reset via recovery mode. This will definitely be the best solution 👍✅. Consider it as our solution by clicking 3 dots on right and accept it as our solution
