Battery drain issue due to camera light sensor in samsung galaxy A51
(Topic created on: 07-14-2021 05:17 PM)
Dhanushvarma
Getting this problem for the past 3 week, this camera light sensor consumes particular percentage of battery daily, but haven't had this problem before..any solution to fix this problem, my device is Samsung Galaxy A51.
32 Comments
Turn off adaptive brightness and face unlock..
navisingh
Yes you are right its draining a lotScreenshot_20210714-183021_Device care.jpg
Dhanushvarma
Yes, Recently many of them facing this same kind of issue
Find this system app in settings apps then open app info of this app then clear cache and force stop
Gourav_Sen
Turn off adaptive brightness.
If this solves your query then accept it as solution by tapping on three vertical dots of my comment and click accept solution 🙂
Dhanushvarma
After turning off adaptive brightness, I am also facing the same issue
Gourav_Sen
Do you use face unlock if yes then turn it off becoz it uses camera senser all time so It drains battery
Same with adaptive brightness
Dhanushvarma
I am not using face unlock
Gourav_Sen
Observe for 1 or ½ day then see
