Resolved! Solved
Battery drain Problem
(Topic created on: 11-08-2020 05:25 PM)
PunithShetty
My A30 phone is very fast battery drain please help me
3 Solutions
Ehsank
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Ehsank
if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comment
Ehsank
other than that those battery settings also help in this regard with certain limit
10 Comments
PaTiL10
reset mobile
PunithShetty
i am already hard reset not solve the problem the same problem are there
PaTiL10
then go to service center
Ehsank
A. Wifi scanning
A. Adaptive battery
PunithShetty
tq bro
Ehsank
PunithShetty
bro once solution please heavy heating problem in Samasung Galaxy A30
Ehsank
bro, regarding heating you can't do much more, as its normal with exynos, but you try may it help
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App
and if heat during charge , Remove back cover
put mobile from display side while on charge
and if still feel heat then charge few hrs on flight mode
if possible
and if during game then its quite normal
Ehsank
