03-21-2023 10:15 AM (Last edited 03-21-2023 10:27 AM ) in
Galaxy A- Mark as New
03-21-2023 10:22 AM in
03-21-2023 10:25 AM in
03-21-2023 11:18 AM in
Galaxy ABut you may use lower brightness... eye comfort and data saver.... also turn off always on display mode.. so battery will run more.
03-21-2023 11:23 AM (Last edited 03-21-2023 11:24 AM ) in
03-21-2023 12:20 PM in
07-23-2024 11:06 PM in
07-23-2024 11:14 PM in
03-21-2023 07:47 PM in
03-23-2023 02:23 PM in
Galaxy ADear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
