rudra1607
08-05-2025 12:23 PM in
Please tell me how to solve the speaker problem
4 Comments
BiRdMaN
08-05-2025 01:26 PM in
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
rudra1607
08-05-2025 01:31 PM in
Thank you
goodthings
08-05-2025 04:46 PM in
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and go to service center for check and resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
