Resolved! Solved
battery problem
(Topic created on: 08-19-2020 06:38 PM)
shameermuhammedpm
Community Guidelines
My battery is draining from two days
Give any solution
2 Solutions
Ehsank
and if this comment is useful and informative then please accept as solution by clicking on 3dot at my comment
Ehsank
well come but what more help brother?
6 Comments
Ehsank
do these settings to save more battery life
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Steps to enable developer option
settings >about phone>software information >then u find build number >tap 7 times>then back to settings
and at end of settings one new option called developer option
click on it and find that option
then go to settings >apps>search Google >notifications >and disable all unnecessary notification as Google has huge notifications settings which consuming lots of battery.
good, thanks sir
I expects more help from you
Ehsank
Ehsank
Not applicable
All mobile faced battery drain issue wait for next update bro and send feedback to samsung via member app
thanks sir
more helpful
