a50 battery & network problem solution
(Topic created on: 12-03-2019 06:45 PM)
mitesh1410
Community Guidelines
A50 battery &network problem solution
2 Comments
Møňū
it may fixed in android 10 update
Samsung_Support1
Hi there,
Please perform the following steps to resolve the issue:
1) Ensure that network frequency of your device is selected on Auto-mode.
Settings > Connections >More Networks > Mobile Networks > Network Mode > Select Auto mode (GSM/WCDMA/LTE)
2) Search for the Network Manually by the steps as mentioned:
Settings > Connections > More Networks > Mobile Networks > Network Operators > Select Manual Search.
3) You may check by exchanging the SIM in SIM slots and also try using different network operators.
If still issue persists then we would suggest you to contact your service provider.
For further assistance, register your concern in Samsung members application (Open Samsung members app >> click on “+“icon > send feedback >> error report / ask question).
Please elaborate what exact issue you are facing in battery (Battery not charging, slow charging or battery drainage etc.) so that we can assist you accordingly.
Regards,
Team Samsung Members
