Charging Solution [Why I Facing Slow Charging]
(Topic created on: 03-30-2021 06:58 PM)
PratikGoswamiPM
Community Guidelines
Now A Days I Seen Many of People Are Writing That They Facing Charging Issue,
But It's a Common Issue and That is Happening Because of Summer Season.
Now I Telling Why I Used Summer Season,
In Summer Season Temperature is Gonna Up to 40⁰ to 45⁰ So Battery Temperature Also Increase and While It's Increased You Will See Battery Percentage is Reducing Fast and You Will Going to Plug In for Charge Battery But Battery Temperature is High So Fast Charging Method Will Not Work and Charging Percentage Will Increase Like 3/5 Min Per 1%,
So My Advice to All You People Charge Your Phone Between 15⁰ to 38⁰ C, So You Will Able to Charge Fast and Will Not Facing Any Issue.
Here's You Can See Some Screenshots for Battery Charging Issue and Which App I Used for Seeing Battery Temperature.
This I Captured Morning After Charge Complete
This is Today's Photo and You Can See Almost 2 Hour in Charge But Can't Able to Charge Full Device, That Because of Battery Temperature.
I Used Ampere App for Checking Battery Temp.
73 Comments
vikas33346
See
Sahi hai
HECKER_Sr
Expert Level 3
Is it M31 Prime? Why is it M317F?
rock1232
No it's m31s dunno
HECKER_Sr
Expert Level 3
See it on settings about phone and check the name
M31s Ka M317F Hi Rehta Hai 🙄🙄
HECKER_Sr
Expert Level 3
Mujhe pata nahi tha 😅
Achcha Achcha
rock1232
Ok I am sending you refer the image
HECKER_Sr
Expert Level 3
Thanks bro 😅 understand
