Charging Solution [Why I Facing Slow Charging]
(Topic created on: 03-30-2021 06:58 PM)
PratikGoswamiPM
Community Guidelines
Now A Days I Seen Many of People Are Writing That They Facing Charging Issue,
But It's a Common Issue and That is Happening Because of Summer Season.
Now I Telling Why I Used Summer Season,
In Summer Season Temperature is Gonna Up to 40⁰ to 45⁰ So Battery Temperature Also Increase and While It's Increased You Will See Battery Percentage is Reducing Fast and You Will Going to Plug In for Charge Battery But Battery Temperature is High So Fast Charging Method Will Not Work and Charging Percentage Will Increase Like 3/5 Min Per 1%,
So My Advice to All You People Charge Your Phone Between 15⁰ to 38⁰ C, So You Will Able to Charge Fast and Will Not Facing Any Issue.
Here's You Can See Some Screenshots for Battery Charging Issue and Which App I Used for Seeing Battery Temperature.
This I Captured Morning After Charge Complete
This is Today's Photo and You Can See Almost 2 Hour in Charge But Can't Able to Charge Full Device, That Because of Battery Temperature.
I Used Ampere App for Checking Battery Temp.
73 Comments
Nahi Me Movies Bahut Kam Dekhta Hu But I'll Watch That Movie for Sure
HECKER_Sr
Expert Level 3
I was also stopped watching movies but right now I just remind it and I make a Meme on it😍🤣🤣
Cool cool
HECKER_Sr
Expert Level 3
Pagal ban gaye 🤣🤣🤣🤣
Kiya Kya Vo to Batao 🙄
Usse Battery Calibration Hota Hai Bhai
Ayush-7
Means abhi ki jo battery ki condition hai uss hisaab se battery ka mah batayega? Lekin battery toh same hi rehti hai na means uska mah toh kya change hoga
This will do battery calibration ,with this it will delete old battery stat that is store in your device in .bin format, and regenerate the new battery data according to charging.
Ayush-7
Means like mere me 6000 mah ku battery hai so if me ab isko use karu toh abhi latest jo battery ka performance hai uss hisaab se battery ka mah batayega?
vikas33346
Purine I phone to 1 hour me 100 to 0 ho jate h and mere m31 to 1.2 1.3 percent Kam hota h 11 min me
