Battery problem A51
(Topic created on: 11-21-2021 11:42 PM)
74756
Community Guidelines
Sir my mobai is A51 charjing fast drain problum 100% full charging only 22 hors
2 Comments
deepcat89
Optimize battery usage in battery settings, remove unwanted apps ,disable unused apps to sleep/deep sleep . Turn off location, Bluetooth . Use dark mode ,keep brightness less than 30% in indoors.
cs-member13
Expert Level 4
Dear Samsung member,
Thank you for sharing your concern. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
Warm regard,
