Mobile networks and battery life issues
(Topic created on: 06-26-2020 08:47 AM)
Biplabkumarr
Bengaluru
I am using Samsung a750f. Before it's working good  but after update android 10 I am getting network issues and I can't able to use internet. I think may be my sim cards issues so, i change to new but i am getting same issues.
Note-: same sim cards I will put another device like vivo and mi it's working good. But why not Samsung  ??.
And, my device taking 4 hours above to get full charge.
Please suggest
Regards,
Biplab
2 Comments
Samsung_Support3
Bengaluru
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
1. Check device network mode settings
Settings > Connections > Mobile networks > network mode SIM1 or SIM2 > network mode.
2. Check network operator settings
Settings > Connections > Mobile networks > Network operators > Select automatically > OK > Registered on network.
Note: We recommend to set device network operators as LTE/3G/2G (auto connect) mode.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Biplabkumarr
Bengaluru
everything did but still not solved issue.
