Battery issue of j2 prime
(Topic created on: 11-02-2020 07:38 AM)
puni87
Bengaluru
Battery not charging properly
4 Comments
AMPK
Expert Level 3
Bengaluru
Always once 15 days drain the battery to zero switch off charge to 100%. Future keep charging to 80% for better battery life.
FearLesS007
Bengaluru
use original adapter cable
puni87
Bengaluru
I'm using original charger
cs-member13
Expert Level 4
Bengaluru
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve the charging issue kindly follow below given steps:-
1. Kindly check the power socket functionality with a different device or try to charge the device in a different power socket.
2. Charge the device:- Please charge the device in switch off condition for a minimum of 10 minutes.
If not resolved: (Removable battery) – Kindly remove the back panel of your device and check the physical condition (Bulge, Swelling or visible damage).
If the physical condition is not good: Request you to turn off the device immediately and please do not try to charge or tamper the battery also request you to visit the service center immediately.
For more information kindly check the instructions provided in below given link:-
https://www.samsung.com/in/support/mobile-devices/battery-not-charged-charging-related-issue/
After performing the troubleshooting steps if the issue still persists, kindly get back to us with additional information- Error log File, Video or Screen-shots. This will help us to further investigate and resolve your concern.
(Samsung Members app > Get help > Feedback > Error report/ask question).
