Tips for battery-draining issues
(Topic created on: 06-08-2025 06:35 PM)
Sbonga99
with Galaxy
I found them on Google
8 Comments
Conshop
with Galaxy
I just hope that this update doesn't put me off Samsung
Sbonga99
with Galaxy
Have you received it 🙂
Conshop
with Galaxy
Yep
Sbonga99
with Galaxy
👏🔥... did you also encounter the battery drain issue?
Conshop
with Galaxy
Everyday, I've done everything but the battery isn't the same anymore, maybe I should switch off sync
Sbonga99
with Galaxy
Oops💔.... but bare in mind that you'll need to sync accounts manually to collect recent information & you won't receive updates
Conshop
with Galaxy
I'll probably forget to do it manually but we'll see
Sbonga99
with Galaxy
😀 alright
