Left bud 3 Pro won't charge and is at 2%. Right bud charges just fine.
(Topic created on: 03-04-2025 07:07 PM)
BraMelo
Wearables
My left Bud 3 Pro is almost dead and won't charge. I have tried all suggestes fixes on the Internet but nothing is helping. Please help!!!
9 Comments
Wearables
Did you try resetting them in the case?
BraMelo
Wearables
yes. I have tried every fix on the internet.
Wearables
My advice would be to take the buds in under warranty and that should solve your problem.
BraMelo
Wearables
thanks buddy...
Munatsi399
Wearables
Did they take a fall recently, if so it could be as a result of that, or it might be a faulty that has developed you might need to take them to a service centre
BraMelo
Wearables
no, none of the buds have fallen recently. Both buds usually do this but the battery has never been this low.
Munatsi399
Wearables
It might charge then. But you might want to get them checked out
BraMelo
Wearables
thank you for your time... 🤙🏿
VeronJuan
Wearables
My left bud has just started not charging at all,did you fix yours?
