donovangregg293 6
10-08-2023 09:57 AM in
Others
This is really and truly getting annoying Samsung that you.s haven't yet fixed or rectified these problems
- Tags:
- absolutely
- annoying
3 Comments
donovangregg293 6
10-09-2023 12:16 PM in
Others
Thanks for the help but I have done this before and none of the above works
khumsha_max
10-09-2023 02:07 PM in
Others
That is solely caused by running many apps on the background while also surfing the internet with an immense amount of traffic at the same time
You should at least close background apps and restrict those apps that run in the background even when you're not using them
donovangregg293 6
10-09-2023 02:17 PM in
Others
I have all applications closed I still experiencing these problems
