theme store problem
(Topic created on: 12-20-2017 06:04 PM)
RonieRf
can someone help me!!
o cant preview any of the themes on my S7 theme store,I cam only download themes and then get to see what do they look like!!
10 Comments
Amicoe0808
same issue with my note 8
Amicoe0808
You have to change the DNS1 & DNS2 in network setting.
Go to Setting>Connections>Wi-fi.
Select the SSID of your wifi by long press over it. Then select manage network setting, tick show advanced option.
Then change DNS1: 8.8.8.8
DNS2: 4.4.4.4
RonieRf
i couldnt find the DNS1 or 2
jmcynd
I have the same problem and this solution actually worked. Thanks!
Abdolbasir
hi, may I ask what happens if we change DNS to these new numbers?
I mean do this change effect on something else or not?
mynaji
Me too! I don't know why ?!
Amicoe0808
you have to change the IP Setting to "Static" in order to see the DNS setting.
RonieRf
thank uuuu soooo much
tati
where to find this option pls
