should I test my s7 edge on water?
(Topic created on: 07-11-2017 12:06 AM)
Faisalkhan1
hello everyone today I have 1 question to ask you.
is Samsung galaxy s7 edge water resistance? should I drop my phone in the water. I am so worry hopefully it is water resistance. but first I want to ask you if they're water resistance.
Thank you.
21 Comments
MOHD24
Yeah . You can use the phone in water up to a depth of 1.5 meters, not salt water.
Faisalkhan1
What?!!!! not salt water? tomorrow I am going to swimming pool and testing my mobile on salt water.idk they might use salt or there type of water.
adhi1
can we take photo under pool water with d7 edgr
Reza78
yes
Reza78
if you want take picture in water you should set timer to capture because touch dosent work!!
yes....obvio....trust us...it works
KHAN86
yes it works my friend did under water photography yesterday in swimmimg pool
Sexyboy
no it doesnt work
ismailalbloushi
my WiFi network not can't program
