imi1
Beginner Level 5
06-21-2016 02:09 PM in
my s7 edge is taking way too much timing to charge it says approx 1 and half hour but it takes 3 and half hour to charge by using original charger and with fast charging option on,since last 2 days im facing this issue
5 Comments
shalom6793
06-21-2016 02:13 PM in
Try a new charger if it doesn't work service center would be the last option.
MiDoSaMi
06-22-2016 01:14 AM in
Make sure the port isn't wet by any chance
imi1
Beginner Level 5
06-22-2016 11:50 AM in
new charger does it ok now ,thanks guys
aramis
06-22-2016 01:43 PM in
try change charger or usb cable.. while charging, you wgo to notification panel and notice that you will find info that the phone is charging slowly or charging faster
jadzz
06-22-2016 04:49 PM in
factory reset your phone
