in right edge of screen transparent pause previous chater ,next chapter icon e
(Topic created on: 09-01-2020 08:49 PM)
pgangwani786
In samsung galaxy s8 plus
in right side edge of screen transparent pause previous chater ,next chapter icon and lock icon are displaying and
Thank you for contacting Samsung. We hope your query was answered satisfactorily. For
future reference kindly quote 1161387884 at
I try in safe mode also but same problem is displaying even i  check my software is already updated please help me
Non rooted
Android 9.0
Please help me
11 Comments
Hi, can you attach some screenshots of your concern.
pgangwani786
in screenshots nothing is displaying dear
Have installed any new music or media app recently?
pgangwani786
I check in safe mode but same problem in safe mode also
If so the best solution is to reset your phone, since that Safe Mode couldn't isolate the cause of this issue.
pgangwani786
how to reset phone dear
1st you need to backup all you contacts, messages, files, photos, videos, settings, then you have to go to Settings > General management > Data factory reset.
Hi,
Before resetting your phone, just try resetting app preferences, so that you won't loose any data.
Open settings > apps > click on the 3 dot menu on right top > reset app preferences. This will reset the permissions for all apps to default. Let us know the result.
pgangwani786
reset app preference and setting/ general management/reset settings
also both thing also done but still same problem dear what should I do
