how to get volt update uae for s7 edge
(Topic created on: 08-09-2018 06:18 PM)
FaisalFaisi
please update volt option s7 edge uae
8 Comments
Phoenix7
it depends on region you purchase the phone and region you use it
FaisalFaisi
now i am india
Phoenix7
flash it with stock ins csc firmware via odin... search in youtube for tutorials
Nassil
just factory rest and select country india, you will get updation
Phoenix7
no.... It depends on firmware upto s7 series.. need to change firmware manually
Nassil
last update india volte enable
Phoenix7
no... you are wrong about s7 and below series....
Srvsh
s7 edge globally supports volte.
please check your network provider supports volte or not.
in india , only jio supports volte
airtel , idea, vodafone does not.
if network supports volte you will get indication on the notification panel
