09-29-2021 09:58 AM (Last edited 09-29-2021 10:00 AM ) in
09-29-2021 12:44 PM in
Galaxy SHi, charlie_za apologies for the inconvenience caused, please follow the steps below for the Camera:
1. From the home screen, swipe either up or down to access apps.
2. Select Camera.
3. Select Settings.
4. Select Reset settings.
5. Tap Reset.
To save power, do the following:
2. Select Settings.
3. Select Battery and device Care.
4. Select Battery.
5. Turn Power Saving mode on.
6. Select Background usage limits.
7. Tap the slider next to "Put unused apps to sleep"
10-04-2021 07:49 PM in
10-11-2021 10:33 AM in
Galaxy SGood morning, Charlie_za apologies for the delayed response, please be advised that the App download speed is determined by the network coverage used on the phone.
If you are downloading using Wi-Fi and it is connected to more than one device, this can impact download speed, follow the steps below to activate the network switch functionality.
- From a Home screen, navigate Apps. > Settings > Wi-Fi.
- Tap the Menu icon. (located in the upper-right).
- Tap Advanced.
- Tap the slider on the right next to Switch to mobile data.
