Will the Samsung Galaxy S23 Ultra's battery be replaced under warranty?
(Topic created on: 02-12-2025 10:28 PM)
Furistic
I'm experiencing drastic decreases in battery life even after charging to 100%. I observe that the battery reduces within half a day. My S23 Ultra is under warranty. Can I claim a battery replacement, and how do I proceed?
8 Comments
Please visit nearest Samsung service center and show them issue.
You need to prove that "drastic" Battery performance reduction.
MSTanwar
I wonder if this has been done intentionally, like has it become standard market practise just before the launch of a new version of the phone. I have a s23+ and noticed the same, found myself charging twice or thrice in a day which never used to be the case before.!
BasilJJ
This is my battery health since I bought my s23 plus. Every update kills the battery.1746539539998.jpg
Romeo45
Beginner Level 3
omkc50
first conform that you have battery issue .after you have to go to surf dg centre at uae .if you out of uae go to nearest dealer .
• Ten tips to improve Samsung Galaxy S23Ultra battery life include: reducing display brightness and sleep timeout; limiting background app activity; lowering screen resolution and using a static wallpaper; turning off Always On Display; disabling unnecessary wireless connections and location services; avoiding using the phone while charging; updating software and apps; checking signal strength; and enabling power saving mode.
If your battery is draining abnormally fast, you might be eligible for a replacement under warranty, but it depends on Samsung's battery health criteria. First, check your battery usage in Settings > Battery & Device Care > Battery to see if any apps are draining it. If the issue persists, visit a Samsung service center or contact support for a battery diagnostic. If the battery health is below their acceptable threshold, they should replace it under warranty 😊
Samsung_specialist
Kindly be aware that for any part replacement it need to be checked from authorized service center kindly visit them to check it :https://www.samsung.com/ae/support/service-center/
