02-18-2024 03:13 AM in
Galaxy S- Mark as New
02-18-2024 06:56 AM in
02-18-2024 11:40 PM in
02-22-2024 10:53 AM in
Galaxy SHere are some considerations and steps you can take:
1. Resolution Mismatch: The lagging and overheating issue may be due to the resolution mismatch between the FHD content and your 1440p monitor. The TV may struggle to upscale the content to match the higher resolution, resulting in performance issues.
2. Anker Hub and Samsung DeX: Using a Samsung DeX setup with an Anker hub can potentially provide a solution. Samsung DeX allows you to connect your Samsung Galaxy device to a monitor or TV and use it as a desktop-like experience. An Anker hub can help facilitate the connection and provide additional ports for peripherals.
3. Connection Setup: Connect your Samsung Galaxy device to the Anker hub, and then connect the hub to your 1440p monitor using an appropriate cable (e.g., HDMI). Follow the instructions to activate Samsung DeX mode on your device.
5. Streaming Content: Once Samsung DeX is activated, you can stream content from your Samsung device to the monitor or TV. Launch the desired streaming app on your device, select the content you want to watch, and it should display on the monitor in DeX mode.
3 weeks ago in
Galaxy SHey Samsung Community,
Using the Galaxy S24 Ultra with DeX for long streaming sessions is a smart idea, especially if you're facing lag and overheating issues with your Mi TV. DeX offers a stable and smooth desktop-like experience, and pairing it with a quality Anker hub can make it even more efficient for watching FHD or even 1440p content on an external monitor. Many users have reported better performance and reduced heat using DeX compared to casting or using built-in TV apps. For the best experience, consider downloading the Telelatino app, a free streaming platform that works great with DeX and offers a wide range of movies and series.
You can learn more or download it directly from the official site — definitely worth checking out!
