S7 Edge Display issue!
(Topic created on: 08-27-2017 10:03 PM)
Cookie1
My s7e display has issues.. When i turn off the auto-brightness and manually dim the display to the lowest at night, pinkish-red lines are visible. This happens when there is some BLACK square or image is opened. The lines form from bottom of display to THAT black box/image.
Now few weeks before.. some GREENISH lines are appearing too..
I know that there are issues with s7e display and permanent pink-line is most that i've heard mear camera(front)
I've reset the display few times from *#0*# but it isn't helping
I bought this phone from UAE and currently using in India. Will samsung warranty will be accplicable. Or is there something else i can do?
5 Comments
Cookie1
The image attached was captured in night.. The lines are visible near the word "diagnostics" and these lines are going UP to the black image.
Dhiru1
Definitely a display issue. However you can't avail warranty in India if the phone was bought in UAE.
PANKS1
Bro...u will not get warnty in india..tht is the problem buying a phn outside india...try reaching out to samsung ceo office via their india website...and raise a complaint..see if u can get any help...good luck!
Bhavesh3
It will work fine when the brightness is turned up.
Cookie1
I know that! But this is an issue so i wonder if i could be fixed. But since it's a hardware display issue and warranty won't be applicable here in india, i guess I'll have to live with it.
What scares me is just that this issue doesn't get worse over months!
