S7 EDGE PINK LINE FIX
(Topic created on: 08-14-2018 05:49 AM)
shavezkhan
DEAR SAMSUNG,
PLEASE FIX THE S7 EDGE BATTERY IMPROVEMENT AND ALSO PINK LINE IN A SOFTWARE UPDATE.
MY PHONE IS RUNING 16HOURS ONLY.
THANK YOU
5 Comments
Phoenix7
pink line is hardware issue.. wont fix in software update
Slayer1
Lol. Battery life isn't an issue, but the pink line issue can be temporarily resolved.
shavezkhan
ok LOl.
brother if your having a pink line issue then believe me quickly goes to samsung service center or replace the display because there's no solution rather then changing display because this happens to me .
i survived for 3 months with pink line and after that my phone display is completely dead . go or replace
Open the S7 edge and remove the ribbon cables. Then the ribbon cables back again properly. If it doesnt work take it to a repair
