S24 ultra fingur print sensor not working
(Topic created on: 03-07-2025 09:11 PM)
Johnwickk
The sensor not working and not response , hardware check not giving errors , what should I do.
Busydude
Take this to Samsung direct. Don't try your luck with third party repair shops as it's a new phone. Go to samsung and show the problem. If they cannot fix it, then try getting the sensor replaced (your best option).
