S24 Ultra volume button does not work when playing media in whatsapp,
(Topic created on: 10-05-2024 01:07 PM)
Members_H6kT67G
I have an S24 ultra, while opening and playing media in whatsapp, the volume up and down buttons does not work, after few seconds, we get an error message saying process system is not responding, this issue happens only in whatsapp
in all other apps, the volume buttons work perfectly fine
have tried cleaning whatsapp cache, wiping cache partition, both whatsapp and the phone software is upto date. have tried re starting.
After we clean whatsapp cache, the volume buttons work for few minutes after which it goes back to same problem
additionally have re set all app preferences
Does anyone else is facing the same problem and do you have any solutions, have checked with both samsung and whatsapp
5 Comments
akrammi
Sad to hear this.
Nopes it works fine with.
I have 24U but i have not face this issue so far.
Try to restart your phone..
Oadeniran
https://www.reddit.com/r/whatsapp/comments/1boculk/whatsapp_lagging_freezing_and_crashing_error/
This is a reddit link that shows a lot of other people facing similar problems
A solution still hasn't been found yet
Just like yours, mine is whatsapp based only
Samsung_specialist
Before you try out the below recommendations as to your solutions, be sure to check if your device's software and related apps are updated with the latest version.
Clear App data and cache
This method resolves the Android Apps crashing issue by wiping off unnecessary App data stored in your device. Follow the step-by-step instructions given below to clear unwanted app data and cache.
Step 1. Go to Settings and select Apps.
Step 2. From the list of Apps that appears, select an issued app.
Step 3.Tap on Storage.
Step 4. Tap on Clear data or Clear cache.
Free up space on device storage
Running out of storage space on your Android device is very common because we end up saving numerous files, which occupy a lot of the device's memory. You may delete data such as rarely used apps and unnecessary documents to create space in the device's internal memory for important apps to function smoothly.
Step 2. Tap on More options (three vertical dots) on the upper right corner.
Step 3.Tap on Sort by size.
To delete, follow the below steps:
Step 2. Select an issued app.
Step 3.Tap on Uninstall.
Reinstall the App
Improper App installation may also cause Android Apps crashing problem. You must download the App from the Google Play Store and use it only after it is successfully and completely installed on your device. In case your Apps stop abruptly, delete or uninstall the App from your device and install it back carefully after a few minutes.
Step 1. To uninstall Apps on Android device, go to Settings and select Apps.
Step 3.Tap on Uninstall, Go to Google Play Store and reinstall the App again.
Factory reset the device
Factory resetting your Android device must be your last resort because it deletes all data and device settings. We strongly recommend backing up all your important data prior to a Factory data reset. Follow the steps given below to factory reset your device while it is switched on.
Step 1. Go to Settings and select General management.
Step 2. Tap on Reset
Step 3.Tap on Factory data reset.
Be sure that this will erase all data, including files and downloaded apps.
Samsung_OFtI7Vg
Facing same issue on Samsung Flip4. the volume button does no with when using media files in wats app. other with it is workgin fine on all other app. This is either a phone S/W issue or som thig to do with wats app app. i wne to service center and was told to reset the phone, but nothing happened. same issue persists. no help from samsung.
