S24 Ultra S-Pen writing issues when using magsafe case
(Topic created on: 02-04-2024 09:19 PM)
Mitsurugi_ryu
I have S24 Ultra and using a magsafe transparent case with white halo from ESR. Whenever I'm writing using S Pen around the area where the magnet halo is there are occasional times that it will leave a blank line or areas where i cannot write.
Without the case s-pen work just fine.
4 Comments
Zammi
Not all magsafe cases are compatible with S24 ultra. Some cases break s-pen functionality. Pitaka magsafe case is 100% compatible.
ahmedyaso
If you want to use the s pen remove magsafe connected device it will work, thier will be interference since s pen using magnetic field as well
sms222000
Samsung_specialist
