S21FE does not connect to wifi at all.
(Topic created on: 06-11-2025 08:04 PM)
Mazoezoe
Hi everyone, my S21FE does not connect to wifi, I have done diagnostic here and everything was diagnosed.
Can I get some help please.
24 Comments
Try to restart it?
Mazoezoe
I did several times
Have u restarted it?
Mazoezoe
Yes several times
Or go to settings, reset, then there's an option where it says reset all network settings. Click on it and it will restart your Wi-Fi immediately. Once done, put in all your Wi-Fi information and I'm sure it should work successfully and connect well.
Mazoezoe
Ok I will do so, thanl you
Mazoezoe
It says I will lose all personal data 🤷‍♀️
No you won't lose the data u bought, it will just reset your network settings.
And it will help u reconnect to Wi-Fi
