Problem
(Topic created on: 03-29-2024 08:37 PM)
Sito_
I did not receive the Android 14 update on my device. What is the reason? Can someone help me? Device model: SM-S918U Baseband version
 S918USQS1AWIG
10 Comments
Zammi
This is an USA AT&T unlocked model. You will not get updates outside the USA AT&T network.
Sito_
Is there no other solution to update?
Zammi
Please check with a phone repair shop to see if they can help you to flash middle east software. Some phone repair shops do that.
Sito_
Will it be an official system without affecting the phone’s performance? Can you help me download the appropriate system for my phone and do the rest of the steps? Thank you, brother.
Sito_
The only thing I need is to download the appropriate system for my phone, and the rest I will do. I have some experience with phones.
Sito_
I downloaded this system but I am not sure if it is suitable or not. Can you confirm?1711736341971.jpg
Razià
Really
Samsung_specialist
Try to Software update via Smart Switch
Step 1. Connect your device to your computer using the USB cable provided with your device, and then open Smart Switch on your computer.
Step 2. If a software update is available, Smart Switch might automatically prompt you to update the software or will display an option to update.
Step 3. Click Update and use the on-screen prompts to download the necessary files.
Step 4. Click OK to proceed. Your device may turn off and on a few times during the update process. When the update is complete, the device returns to the Home screen.
You’re going to need a copy of Smart Switch installed on your computer and your mobile device. Using Smart Switch’s computer version, update your device with the latest software.
For more details about how to update software using Smart Switch visit our website :
https://www.samsung.com/ae/support/mobile-devices/how-to-update-software-using-smart-switch/
AnthonyDS7
none of this works been trying for 3 days for a device like the s23 ultra the support is VERY dissapointing i will be considering switching to IPHONE because even though apple is a locked down type of system whats the point of buying the open unlocked one when its worse. very dissapointed in samsung.
