Problem with wifi and battery percentage display
(Topic created on: 07-11-2025 09:56 PM)
decentdevil
In the last 10 days, my Samsung S25 Ultra has been behaving very weirdly. Whenever I connect to wifi, the wifi icon disappears and the battery percentage display is stuck. I have tried Samsung support and members feedback option but there is hardly any help. In-case someone faced similar problem and got it fixed, please let me know.
7 Comments
foxonlyy
Expert Level 3
Hi brother, I'll answer your question simply. You should head to the nearest Samsung Maintenance Center Looks like a new device and you have a warranty. I advise you to go to them and don't act wrong. Advice from me. Go to the nearest maintenance center. They'll help you as soon as possible. They have a solution that needs light programming. If the solution is accepted, click on three points above and click on The solution has been accepted, and thank you for your question, and I give you the best solutions. 😊
decentdevil
I did a factory reset and it's working fine now.
ojwh
Great. Sorry you had to go that route. Resets aren't fun, but glad everything's fine now. Enjoy your device.
Samsung_specialist
We’re sorry to hear about the issue you’re experiencing.
Kindly try these steps in order :
Settings -> General management -> Reset -> Reset all settings -> reset.
Then kindly restart your mobile then:
1. Settings > Software update > Download and install > Download > Install now.
2.Settings > General management > Reset > Reset network settings > Reset settings > Reset.
If the issue persists after the visit, please don’t hesitate to contact us again.
decentdevil
The problem has started again since yesterday. I did all the steps you suggested. May be I need to leave it at the service centre.
MUKSITHASLAM
alghonemy
I have z fold 4 , and since I made the last system update and the wifi is not activating, Bluetooth is working fine , but the wifi shutted down suddenly, and not activating since 2 days , I made reset for sittings and still the issue not fixed ,
Pls help me. I can't do my work since todays,
Waiting your replay
