Pro tips-4 Flash notification
(Topic created on: 05-07-2023 04:56 PM)
salmanul
Expert Level 3
Flash notification is a feature on Samsung devices that uses your phone's camera flash or screen to alert you of incoming calls, messages, or notifications.
There are two types of flash notification on Samsung phones: camera flash notification and screen flash notification.
Camera flash notification is the original and most common type of flash notification. When this feature is enabled, your phone's camera flash will blink repeatedly to let you know you have a new call, message, or notification. It's great for people who might not hear their phone ringing or vibrating, especially if you work in a noisy environment or have trouble hearing.
Screen flash notification is a newer feature that uses your phone's screen to alert you. When this feature is enabled, your phone's screen will flash repeatedly instead of the camera flash. This can be useful if you find the camera flash too bright or if you're worried about draining your phone's battery too quickly.
To enable camera flash notification or screen flash ,go to Settings, then Accessibility, and then Advanced settings and select Flash Notification
That's it! Once you've enabled either of these features, you'll get a visual cue when you have a new call, message, or notification, which can be really helpful if you're in a noisy environment or have trouble hearing.
Follow me for more tips and don't forget to like this Post
