Overheating problems
(Topic created on: 02-02-2025 10:17 AM)
sainterc20
Why is my s24 ultra overheating when im making video calls ?
3 Comments
Munatsi399
According to my research,
video calls are considered a resource-intensive activity, requiring the phone to simultaneously use the camera, microphone, screen, and network connection, which can generate significant heat, especially if the call is lengthy or has high video quality
if the heat becomes excessive, check for factors like a phone case hindering heat dissipation, poor network connection causing extra processing, or potential software issues that might need troubleshooting.
sainterc20
Ok thanks bro I'd look into it
POTENT
Video calls generally uses more battery and processing.
