HarisArif
11-21-2022 06:51 PM in
Galaxy SHi i have samsung s22 ultra, and for the few weeks i have been experiencing issue with my mobile data as it shows connectivity but in actual it does not work.
When i check sim status so sometimes instead mobile data as LTE it show something different and than i have to again reset my settings and than it works fine.
2 Comments
Zain1999
11-22-2022 12:09 AM in
I recommend, removing and reinstalling the sim card, then a soft restart, by pressing the power button and clicking restart. This will fix the issue.
Kamel20
11-22-2022 12:28 AM in
go to settings / connections / mobile networks / access point names / more or the 3 points at the top / reset to default
restart
also try to switch between connection type 2G 3G 4G / 5G
i hope thats help
restart
i hope thats help
