saadd1
01-27-2024 05:44 AM in
Yes, it was resolved yesterday
I reset all my settings, and i uninstall all the updates for the system app
Then again, after a few minutes, i got new updates on google Play for those same system apps, and then I updated it again.
After that new updates, it starts working
kryshnakishore
03-29-2024 02:28 AM (Last edited 03-29-2024 02:28 AM ) in
Galaxy SHi may I know which System Apps you have reset ? I am facing the same issue. Language packs aree showing empty.
Hi may I know which System Apps you have reset ? I am facing the same issue. Language packs are showing empty. Because of this I am unable to use AI features
