Keyboard tap sound
(Topic created on: 04-20-2024 07:25 AM)
Ace-AME
Beginner Level 3
After the recent update. I am unable to stop the keyboard tap sounds when using Samsung keyboard. Literally tried everything. It's not an issue on the GBoard. Samsung please fix this! This update has a lot of bugs.
5 Comments
Qusaimoh
You can try force resetting the Samsung Keyboard.
Follow these steps carefully to reset your Samsung keyboard:
From Settings menu, go to General management.
Select Samsung Keyboard settings.
Select Reset to default settings > Reset keyboard settings.
Ace-AME
Beginner Level 3
No help bro
Which device are you using?
I am assuming you have tried turning off the system sound.1713600663587_1713600663565_0.jpg
Ace-AME
Beginner Level 3
Thanks a lot buddy this helped!
Samsung_specialist
Try from Settings > sound and vibration > System Sound and toggle off keyboard sound
