How to fix camera failure issues on galaxy s21+
(Topic created on: 02-01-2025 07:04 PM)
Murphy123
4 Comments
marjen
Munatsi399
Restart your phone: This is the simplest solution and often resolves minor software glitches.
Clean the camera lens: Use a soft, microfiber cloth to gently wipe the lens.
Check for software updates: Go to your phone settings and ensure you have the latest software version installed.
Clear the Camera app cache: Open your phone settings, go to Apps > Camera, and then tap "Clear cache".
Reset Camera app settings: Open the Camera app, go to Settings, and select "Reset settings".
Check app permissions: Ensure the Camera app has the necessary permissions to access your device camera.
Boot into Safe Mode: Restart your phone in Safe Mode to see if a third-party app is interfering with the camera.
Contact Samsung Support: If the issue persists after trying these steps, reach out to Samsung customer support for further assistance.
Masaya
Beginner Level 3
My Samsung galaxy s21 is keep on clossing automatically and sometimes the clipboard doesn't appear on the screen, what could be the case? And when I'm recording a video the saving button doesn't work, please help.
Munatsi399
Low storage space can cause this.... how is your storage
