Help with issue
(Topic created on: 01-02-2025 12:25 AM)
ghostwire
My samsung s21 5g doesn't show fingerprint and face so I can't unlock my phone using both it only unlocks with pin please help if you can
11 Comments
Check Security Settings
Go to Settings > Biometrics and Security.
Check if the options for Fingerprints and Face Recognition are present and enabled.
If they are not visible, there might be a system glitch or misconfiguration.
Software Update
Ensure your phone is running the latest version of Android and One UI:
Go to Settings > Software Update > Download and Install.
Restart Your Device
Sometimes, a simple restart can fix temporary software issues:
Hold down the Power button and select Restart.
Re-Add Biometric Data
If the options are visible but not working:
Go to Settings > Biometrics and Security > Fingerprints or Face Recognition.
Delete existing data and re-register your fingerprints or face.
Restart your phone in Safe Mode to check if a third-party app is causing the problem:
Press and hold the Power button, then tap and hold Power Off until you see Safe Mode.
If biometrics work in Safe Mode, an app may be interfering.
Clear Cache Partition
Turn off the phone, then:
Hold Volume Up + Power until the Samsung logo appears.
Navigate using the volume buttons to Wipe Cache Partition and confirm with Power.
Select Reboot System Now.
Factory Reset (Last Resort)
Backup your data first, then:
Go to Settings > General Management > Reset > Factory Data Reset.
Hi, If None of These Work It could be a hardware issue or a more significant software problem. Visit a Samsung Service Center for further diagnosis and repair.
ghostwire
Thanks
