Display Problem
(Topic created on: 01-02-2025 12:46 AM)
Anoc1924
My S24 Ultra screen light up slightly like LCD screen at night while charging.
Being a amoled it light up like LCD slightly and shows down charging information.
Samsung_specialist
It sounds like your Samsung Galaxy S24 Ultra is showing a faint glow on the screen while charging, اere are a few things you can try to manage this:
- Check Always-On Display Settings:
Go to Settings > Lock Screen > Always On Display, and make sure it's turned off if you don’t want any display visible at all while charging.
- Turn Off Edge Lighting:
If the light is coming from the edges of the screen, check Settings > Display > Edge Screen > Edge Lighting and toggle it off.
We hope this helps.
