Resolved! Solved
Dex using usb c to usb c cable.
(Topic created on: 09-24-2020 11:04 AM)
Joe82
Just curious if the charger cable is able to activate dex? Currently using the usb c to usb a cable that came with the phone to run dex on the pc. Planning to use a portable monitor so wanting to check if thats possible.
Squachbob
you can use it directly use it on a monitor if it have a usb type c port
6 Comments
Squachbob
Yes your type c to type c cable will be able to do that
Joe82
thank you for the fast reply. am I correct in assuming that the cable supports display port capabilities and am able to use directly into a portable monitor?
Squachbob
Joe82
thank you
Squachbob
have you tried it with a monitor with a type c port?
Joe82
not as yet. awaiting a delivery of the monitor but since noticed that my current device only accepts Samsung usb c cables and has difficulty with other gen 3.1 ife cables. so just want to be ready if the included cable does not work.
